ljmasonwy
- Jul 12, 2016
- 28
- 7
- 2016
- 6.7 Cummins Turbo Diesel
I tried plugging an electric drill into the 115v receptacle in my dash (2016 3500 Longhorn Laramie CTD) a few years ago, and it didn't work. IF I remember right, the light at the receptacle was on, I plugged the drill in, and pulled the trigger and it died and the light when out.
I occasionally remember it and tried to fix it. I have gone through all the forums that even mention inverters with not joy.
I have visually and electronically tested every fuse and relay in the fuse box (power distribution center) under the hood. F38 30 Amp, Power inverter, F39 20 Amp Power Outlet Special Services only, F90/F91 20 Amp Power Outlet Customer Selectable, F93 20 Amp Cigar lighter, F100 10 Amp Upfitters if equipped, F104 20 Amp Power Outlet Center Consoles.
I do not have another power center/Fuse box in the cab. I can feel around the inverter and there is a single cable plugged into it, and no reset switch.
Is there anything else I need to check? Is there an upgrade for a bit more power? Any help would be appreciated.
