- Jul 30, 2012
- 3,238
- 5,359
- Location
- Newport News, VA
- 2012 1500 Laramie CC 4x4
- 5.7 Hemi
My 2015's auto climate stays on all the time. They changed this?
Same here......
Mine still kicks into MDS when in tow haul mode. You can hear it in the exhaust.
Yeap mine does as well.
As for the Ram, the headlights are good. But why have the ugly yellowish halogen's and then have bright white LED fogs? Anyhow, winner by a long shot: Ram.
FIRST EVER praise for the OEM RAM headlights.
Same here......
Yep, on 1500, while in Drive (I do it when I'm stopped), push the minus (-) button on the wheel to enter manual mode, then push the plus button next to it and you will see on your dash with each push you increase a gear. Whatever gear you increase to, the truck will limit it's operation to the set gear as maximum. Set it to 8 and the truck will run exactly as normal up to 8th gear with NO MDS.
Any time you set a manual selection, MDS is turned off.
Running in Tow Haul mode also disables MDS.
I was under the impression that tow/haul only disengages torque converter lock-up...it should not affect MDS...Yeap mine does as well.
I went from a 2015 Silverado 1500 z71 to my ram. I echo the Ops thoughts, but will add the G80 locker in my Silverado just plain sucked. never locked up.. useless.
ram is a winner by a long shot. trans in the Silverado is pure garbage. makes the 6 speed in my he seem like a dream. no comparison even if it was 1500 vs 1500
On my 2014 Ram 1500 Big Horn with the 8HP70 transmission, MDS IS NOT deactivated in the Tow/Haul Mode.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 072194 miles.
We all know the 66RFE isn’t perfect but I find it shifts smart and very smooth. Especially if I put it in manual mode to 5th. Just gotta get used to the taller gears and now I don't even think about it or notice it. After it settled and leaned my driving style it has been very smooth. I find it nicer to live with day to day than either of 6L80s I owned. It feels more in command overall than I remember the GM's being, even with a lot of weight in the truck. I remember at times the GMs would just completely be in the wrong gear for the situation. I never have that with the Ram. Driving around town the truck isn’t constantly shifting. It is very composed. An HD/6.4 specific 8 speed would be great, but for now I don't have much to complain about.
Square wheel wells .......... Winner - Ram
