Front and rear differential service with new covers
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
So for future convenience, I replaced my front and rear covers while doing fluid changes today. pretty quick and easy, except the rear cover I had to make a simple 'adapter' for the rear brake lines since the attachment point is not on the aftermarket cover. Also the BD rear cover requires a 1/2 inch spacer (included) for the rear sway bar.
now question: is the fluid service interval the same front and rear? or can the front go longer if 4x4 is not used often?20180513_162104.jpg
SouthTexan
408 CTD
I plan on doing the same at 120k when I have to change the oil again.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Looks great, glad I changed mine when I did my 1500...looks a lot better.
Yours looks good!
fullmonte60
Cummins
reek... can you show a pic of your adapter? i have the BD and was checking things out before cracking it open and saw the brake hardware hanging off two upper bolts/studs. many thanks.
Quyonmob
Canada
I have always based axle service intervals on use.
Been underwater? Change it more often.
Towing tons? Change it more often.
Mechanical locker? Change it more often.
That said, the front sees limited engagement, limited towing loads, and limited submersion (think boat launch), so less often is usually ok.
dexter
Banned
Yes, I tow a lot so I do it every 20K.
check out below for good covers
https://yourcovers.com/differential_covers.html
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
ChloeBrooks
