Front axils loose is it dangerous to drive i can shake the by hand
2014 Ram 1500 5.7. 4x4 front axils loose is it dangerous to drive
If moneys tight,you can remove the front CV axle for now and drive it,just don't put it into 4X4 mode.
My 4X4 hasn't had front axles for going on 10 years,hasn't had the front diff or driveshaft either :Big Laugh:
And "no" the front tires won't fall off,the 4X4's and 2X4's use the exact same front hub,so don't let anybody tell you,you can't run a 4th Gen 4X4 Ram with out the front axles
ChloeBrooks
