Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
1997 ram 1500 4x4 just replaced right side hub and u joint went for a ride and this happens.. what would cause this...I'm stumped ..the shaft was previously replaced to eliminate the va uum actuator ...for 4WD..opened up the up the diff cover no visual physical damage ..thx
Something siezed up, could have been at speed, could have been crawling in 4 low. Ive seen broken joints before, and it really could have been a 1000 reasons. Hows the other side look. If you lift the front completely and turn the other tire does that shaft spin even in 2wd?
