Front bumper question
JCARTER7
NJ
my question is: I have a 2011 Laramie 1500. My front black plastic where everyone puts the curved LEd bar in, is thinner in the middle and wider on the ends. will a led light bar still work? i also have a 3" body lift and for brackets i think that makes a difference as well.
Stewi
My bumper opening in my 14' Express is also a little wider in the ends and narrower in the middle and I had no problems fitting the bar. While I don't have a certain answer about it working with a 3" body lift, I believe it will, without any issues and I'll explain why. I mounted mine to the studs where the bumper support bolts to the frame. When you install a body lift, you install the brackets that raise the bumper support up as well. You would just attach the light bar bracket to the "stud" or bolt where the extension bracket attaches to the bumper support.
jwheeler
Washington
Got any pics, Stewi?
that white kid
i fit a curved 40 double row in mine and it sticks out about 2in but it looks good
Thatdude596
buckeyes state
2009 ram big horn
if yours is the same as my 09 big horn it's not wide enough like the new ones to sit flush, or remotely flush
Stewi
Ohh yeah that's substantially smaller in the center. Ok the plastic bumpers, it only gets slightly narrower. You may be able to get a single row in the.
JCARTER7
JCARTER7
NJ
thats what mine looks like to in the middle.... prob going with a single row led
Raadz
