Front Camera
Michael
In an undisclosed bunker
Do you still have the oem head unit or an aftermarket one?
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas
ALFREDO SILVA
ALFREDO SILVA
Sylmar CA
HEMI 5.7
It’s an
It’s an aftermarket unit that has front and rear. Already have a rear camera.
ALFREDO SILVA
ALFREDO SILVA
Sylmar CA
HEMI 5.7
It’s an
ScLeCo
Earth
Supercharged 426
I have the Brandmotion 360 camera system. I totally recommend it.
NapaRam
Napa CA
Hemi 5.7 L
I have Crimestoppers CAM-300 camera in their license plate bracket.
Looking to do the same thing. Do you need a special harness or lock pick device to get it to work with the head unit or is it just plug and play?
NapaRam
Napa CA
Hemi 5.7 L
Based on your post I got the same one and it works great! I clipped the wires to turn off the lines. It comes with a numbers of mounts which I think makes its one of the better options out there. On the rebel style grille you can't really even see it when placed in the right location.
NapaRam
Napa CA
Hemi 5.7 L
Nice job. Glad it worked out for you too.
Thanks. I hope I can use Alpha to change the timeout so it will stay on longer. It's going to be really nice when parking as I imagine you have discovered yourself. I tapped power from the 12v plug in the dash but it turns out the fuse was burnt out to had to replace that first to get it working.
John Jensen
San Diego County
Ecodiesel
Let us know how the Alpfa process works
NapaRam
Napa CA
Hemi 5.7 L
For reference here is what the manual says about how the camera works. For parking purposes it should be fine but sometimes it would be nice for it to stay on longer at higher speeds but there may not be way to change it.
Chris Murray
Vicksburg, Mississippi
6.7 Liter
My local stereo shop sold me a Metra TEMICM. I mounted on my front grill facing downwards. Some cameras only have mirror/non mirror and parking lines. This camera has 3 settings mirror/non mirror, parking lines, and left to right. This allows you to mount high and face down wards and image be correct. Settings means 3 little wires that can be cut.
Ricky91
