front differential vacuum lines
JMikk
5.2L 318
Hey everyone, the heat in my truck started to get a little weird going on and off. I knew that when that started happening i had broken vacuum line or lines, Turns out the lines to the front differential are broken. Does anyone know the part numbers, i need them ASAP as its going to snow like all hell this weekend and i need my 4 wheel drive!
dapepper9
Iowa/Nebraska Border
5.9L V8
Cut a section out and replace it with simple vacuum line/hose to get you by. That with hose clamps and you'll be good.
Ill find the link to a good place to order new lines though so you can make it a little more permanent.
J
JMikk
5.2L 318
Remove the vacuum lines. Plug them. (delete) Remove your vacuum shifter and flip it so your axle is always engaged. Just like every other truck except our 1500 Rams.
I prefer not to mess with what works, all i need to fix the leak is the plastic hose from the metal lines to the front axle
Bramo
