JimmyP
A couple weeks ago I started to hear a "clunk" in my front end when turning into my work's parking garage (right turn and slight incline). It seemed to happen when the right wheel was up the incline and the left was hitting it. Didn't really feel anything in the pedal or steering wheel but it would be hard to in that scenario. That was the only instance that I heard it at that time.
Then today I started to notice a bit of grinding / clicking and a maybe a clunk when turning right at speed. I can feel the grinding in the steering wheel and the clunk in the pedal a bit. Occasionally it would also click while going straight at about 20 MPH. When turning at low speeds, nothing. I also heard a pretty good clunk when going over a particularly steep speed bump in my apartment complex.
I've searched this and other forums for similar issues and found it could be issues with the CV axle, wheel bearings, break caliper, or steering rack. I've been a little suspect of the brakes on this truck since I bought it and one of the calipers came loose on the way home from the dealer. It doesn't feel like a sticking caliper though so I'm writing that off. Brakes have performed fine since. I visually checked both CV axles and there's no tears in the boots on either side. Nothing visible to the tie rods either.
I don't have access to any tools to really do much diagnosis, but I do have a solid mechanic that I trust. Before I give him a call, any thoughts on what this could be? I usually like going to him with "my own" thoughts on the problem. Anything I can check without jacking the truck up? I guess I do have a couple bricks and my standard truck jack...
