Front end conversion from '04 to '06 Laramie
wowsoHEMI
I'm looking to put a newer front end *grille, bumper, fenders ect..* on my '04 Ram 1500. I know the body is the same except for the front end so I'm wondering if ill be able to just bolt on the new fenders and bumper or do I have to purchase new brackets and supports or what not.
W
wowsoHEMI
swapping from a 2004 to a 2006 Laramie front end.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Hmm not sure if the underbody frame is the same. If you have access to a 06 truck you might want to check out the underbody framework before starting the job. Thing is the headlights will have to b changed out as well depending upon if you go with a later 06 or an earlier one.
moparman
Woonsocket, RI
2016 Ram 2500
Everything bolts on. You would need headlights, fenders, grille and support, upper bumper plastic or bumper cover if you have the sport. I have seen some guys keep their 02-05 bumper with the 06-08 nose swap, and it fits, but if you look close it looks a little odd
Sent from my Galaxy S3 using Tapatalk 2
