Front end lift ideas
DBrown21
Magnum 3.7
I was wondering what I could do for a lift on the front end of my truck, I already have a body lift, 3 inch coil spring spacer, and 3 inch lift spindles for the front end and the truck is still only leveled cause I have a 2 inch rear block on the back, any other 2wd lifts so I can get a more of a bulldog stance. Any ideas?
Stangshcky12
Oshkosh, WI
5.9 Cummins
Only thing you can do is go to a 4" spindle or drop the back
TexasRammer
College Station, TX
^What Cody said. Are you sure the front still sits lower? with that combo you should be 1 inch higher in the front
