muddy12
Didn’t want to hijack the other thread any farther.
Truck info.
2012 1500 4x4 with 4” lift and 35x12.5’s, and around 85k miles.
I have a vibration that comes and goes, and feels like it’s in the front end someplace. At times it feels like an oscillation in the steering wheel, other times the truck just shakes.
The really strange part is that some days the truck is smooth as silk without even a hint of a vibration.
When it does shake, it’s typically between 50 and 60 MPH, and is noticeably worse when going through a gradual turn at those speeds.
So far, on the front end, I have replaced brake rotors, calipers, and pads, lower ball joints, and have had the tires balanced and alignment checked multiple times. I have also inspected(by myself and a shop) the upper ball joints, outer tie rod ends, and wheel bearings. All are, or at least appear good.
Was planning to pull the inner tie rod boots and check the joints this weekend, but don’t think I’ll find anything.
I was just watching a YouTube video about 3rd gen vibrations which now has me thinking I need to check the front dif mounts as well as the front drive and CV shafts.
Does anyone have any experience with elusive front end vibes on 4th gens? Really don’t want to just keep throwing parts at it.
Side note, those D60’s that I had set back for a Jeep build, are starting to look really tempting. LOL
Truck info.
