The worst ones i ever did plugs on were the early Mustangs with either a 390 or 428 in them,if you ever run into an early big block Mustang with holes torched in the inner fenders,you'll know why,lol. The next worst ones to do were the mid 70's Monza's with a 305 or 350,the back plugs on my supercharged 3.8 Buick are a bit of a pain to do to. I've never thought the plugs on the trucks were that bad to do,but i'll agree the worst ones were the back passenger side ones,the drivers side aren't bad if you have the magnetic swivel socket and a short 1" or 1.5" extension.
When you have the coils off,pull the boots and check the springs and contact point under the springs over close for corrosion,i usually wire brush the springs clean,and stretch them out about a 1/4" and use my dremel with one of these brushes to clean the contact point in the coil tower.If the springs are badly corroded you can buy new boots with springs from Rock Auto
High quality Cleaning & Polishing Brushes 443-02 for your project. ✓durable ✓highest safety standard ✓perfect results. Find out more!
www.dremel.com
