Tecxy
I recently replaced my fuel pressure sensor as I had code P018B. This didn't fix my issue. I also verified my wiring. However, I found that on the connector that the pressure sensor plugs into, I am reading 4.78 volts on the signal wire (brown/yellow). The power wire (pink/yellow) reads the expected 5 volts, and all the grounds are good. What could be causing this?
