ramman54
- May 28, 2013
- 28
- 1
- Location
- Glendale, Az.
- 2001
- 5.9 magnum
I've been unable to work since I got hurt over 2 years ago so my baby gets parked a lot when I can't afford the insurance. Went to start it yesterday and it turned over fine but wouldn't fire/start. Let it sit for awhile then turned the key to run position and listened. Nothing. Tried it 3 more times ...same result. Fuse swapped...nothing. Will have helper tomorrow to turn key so I can check relay. But I am thinking fuel pump since it has 168K miles, last time I went to start it. it cranked much, much longer than usual,(Has always fired rightt up) & it would be my luck. Can't really complain since it is the first real problem in 7 1/2 years. Can the pump it self be replaced or do I have to change the whole module? Would also like to hear from those that have done a change out.
