Fuel rail cleaning port
Bill Clune
olean ny
Hi all, I watched my neighbor clean the fuel injectors of his wifes car using a kit from amazon that was <$70 worked GREAT! it attached to a schrader valve on the fuel rail, pull the fuel pump relay then run the engine on carb cleaner. But i cant find the valve on my 2013 5.7 i am a bit disabled so I am hoping to know where the valve is before i jump in, any clues?
Bill Clune
Bill Clune
olean ny
That probably means i need to pull the supply line, probably the better way to do it anyway.
