Fuse84 Causing Parasitic Drain
Huero
Ontario California
5.7 v8
2014 Bighorn 4x4 1500 with dreaded Parasitic Drain on Battery. The dash lights are 100% the problem as they come on intermittently as truck is asleep.The good thing, is that I did the fuse test & found #84 to be the problem. Now I’m hoping that somebody can direct me to the module or wire harness associated w it. I think HVAC might be one of the possibilities & know where that is in glove compartment area but maybe somebody has better info
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
I had a recall notice out for my 2022 classic for this maybe it somehow applies to you as well?
NETim
Nebraska
5.7L
Do the lights come on at a routine regular interval? I always suspect a communication problem between the various modules on the CANBUS. One of them probably isn't answering up is my suspicion.
I'd try connecting to the modules with AlfaOBD to see if I could connect with them.
I don't know what module/computer controls the dash lights.
