Gauge mounts
savage_46
Alaska
6.4 swapped
Not sure if this should go here or in performance. But, are there any A pillar gauge mounts that keep the grab handle? I have a a/f gauge & trinity to put up. I've seen the single mount that goes at the bottom of the pillar, but I need a dual.
Not if you want them in the pillar,the grab handle has to go.There are or were gauge mounts that would put 2 gauges on the top of the steering column and somebody else was making a mounting kit to put them on top of the dash where the coin holder or whatever FCA calls the upper indent in the middle of the dash,lol. I think there's even pic's of them mounted on the dash on here somewhere,but where I don't remember,but if you search for them you should be able to find them.
S
savage_46
Alaska
6.4 swapped
I've seen a steering wheel single & the top dash one. Don't remember how many the dash one had that I saw. I might be able to put up with a steering wheel mount for a/f & the lower pillar for trinity. Can whoever has either setup post up pics or links? My only concern with the steering mount is maintaining cluster visibility.
Not sure how much fabricating you're into,but if you go through Kurtis's build thread,i'm pretty sure he has pic's of how he mounted dual gauges on top of his dash in here somewhere.
https://www.ramforum.com/threads/charonblk07s-build-thread.39221/
S
savage_46
Alaska
6.4 swapped
Went through his build thread, found the jist of it on page 11. That kind of fab is out of my league. In all honesty, I could do away with the pillar handle but I like having it. At the same time, I am fully capable of using the steering wheel to get in. I'm also curious about possibly getting a 3 pod but not sure what to get for the 3rd yet...
