Gear question...
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
Buddy of mine has a 2006 procharged Hemi. Currently, he is running 3.92s in the rear but has 26" rims. I suggested to him to get a different gear (4.10s or 4.56s) Am I correct? What would you all suggest?
Bigboytoys
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
He wants to improve his 1/4 mile time as it is the same as the truck without the supercharger and 20s...
SILVER_BULLET
how many pounds of boost is it pushing?
colbyj1986
His problem is the bigger wheels. Those 26" are heavy.
On my vette I run 15's. I had 20's but it did show a slight slower tine .
My 2008 ram QC hemi I have the 20's it is slight slower start then my 2007 SC 3.6 with 17'
Sent from my SGH-I747 using Tapatalk 2
SILVER_BULLET
The 26" wheels do make a difference but I would of though the blower would of made enough power still to overcome that... Is the rest of the truck stock?
Bigboytoys
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
Yes...He said he is running 6 lbs of boost on the procharger. Current rear end is 3.92s.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Something sounds off in his tune to be blown at 6lbs and not be any quicker then a stock truck on 20's, thats just MHO. Get some times from him or his whole setup, could be starving for fuel if the injectors were not changed. Something just seems really off.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im figuring an extra 150 lbs total for all 4 but could be wrong, normal rule of thumb is each extra 100lbs is a .10 in the 1/4. Does he have the weight of his wheel/tire combo? When I weighed my OEM 20" 04 rim with a 33" Nito Terra Grappler at 50% tread weighed in at 85 LBS.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
yep then take in rotating mass vs static mass, those Amish wagon rims are not helping on a already hefty barge. I would think though that changing to 4.10's or 4.56's will take spin the rpms to fast esp in 1st and 2nd.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
IMO, the tires are the main problem. They are probably something like 36" tall, thats a big tire to get rolling.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Just over 36", I change my mind im with them dang thats alot of wheel/tire
colbyj1986
Those are what I assumed he had. Those are cutting his time down l. If he could get ahold a set of the stock 17's with a good tire size, he will see a better time.
Bigboytoys
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
I convinced him to go with 4.30s. Just need to get in contact with someone from Moe's about ordering them. Thanks for the help guys!
colbyj1986
Did that improve his time
TylerB
FL
If he is really worried about times he shouldn't be running 26s at the track. He needs to get a dedicated set of track wheels with some drag radials PLUS some gears. 4.56s and a set of 28" drag radials will do wonders for his truck.
FYI they don't make a 4.30 gear for the 9.25 rear-end.
