gears
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
how do i find out what gears im running
badfish888
Va beach
2012 hemi express
mine is stamped on the back axle, crawl under there and look, should ne right around the diff. if not, the sticker in the glove box says it to
glass3222
Central PA
You can get an entire build sheet from a local dealer with your vin, or there is a website that you can get one from as well, I just cannot remember what it is right now.
You can also look in you glovebox. There should be a tag in there that says the ratio. If not there, look on the rear axle, I think on the passenger side close to the brakes, there might be a tag there. If you have a 4x4, the front diff cover will also state the ratio.
Bad Habit
Land O Lakes
Modded 4.7l
If all else fails jack the rear up and turn the drive shaft and count how Many times it goes around to one wheel revolution
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
OK, can't get the link to work so here:
Go to www.ramtrucks.com (Official Ram Website)
Scroll to the bottom and click on "contact us"
Click on "Customer Assistance" (second from bottom)
Then click on "Send Us An Email"
As glass stated, just fill out the info and ask for a build sheet, they'll usually send you one in a couple of days.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
^^^ just followed that method to try and get my build sheet
Ramunit
Just tell me what tire size you have and what rpms you are running at 70 mph on the highway, I'll do some math.
BAMA BOY
BAMA BOY
Gasden,Alabama
thanks so the gears are the same front and rear?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep the gears are the same front and back because if there diff you will break stuff all to hell. Im guessing youhave 3.55s due to the year, rim and motor but could be wrong lol.
BAMA BOY
BAMA BOY
Gasden,Alabama
so if i do have 3.55 how would be the easyest way to swap to 4.10 or 4.56
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
open wallet and cry. LOL
You will have to do both the front and the back, and its not going to be cheap!
BAMA BOY
BAMA BOY
Gasden,Alabama
dang thats disappointing i want some low end power
glass3222
Central PA
To get all of the parts and pay someone to install 4.56 gears as well as upgrade to a good LSD like a DTT or Auburn will be about $2k.
ramhunter9
P-Star Jeep Wrangler
or get a truck with the options from the factory . and for the record i love my 4:10's
BAMA BOY
BAMA BOY
Gasden,Alabama
holy **** 2k wow maybe i can find a parts truck and get me a deal i rerally want 4.56s
glass3222
Central PA
You will not find a parts truck with 4.56s, they did not come from the factory. 1500s only had 3.55 or 3.92s from the factory. Plus you need front and rear diffs so that is why they are so expensive. Parts will be about 1k and labor the other 1k.
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
Dude its so worth it. Now that I think of it my truck was such a bag of **** with 3.73's. What a ****. Now its certainly passable and will hold OD on the highway no problem. Towing still blows.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Clay,
A gear change and differiential upgrade is the single best upgrade you can do for your truck. But our trucks are older models and it is unlikely we will ever get the actual cost of the mods back out of them when they are sold. So keep in mind there is no profit in doing it. So figure out what you want your truck to do for you at the end of the day and stick with a plan. That's my 2 cents.. Good luck...
BAMA BOY
BAMA BOY
Gasden,Alabama
really want it have tons of pulling power or well the most i can get
joshhhh
