- Joined
- Jan 17, 2016
- Posts
- 23,817
- Reaction score
- 54,819
- Ram Year
- 14 Sport
- Engine
- 5.7
Don't even look at a Diablo if you have the 8 speed Mike.Alot of the 8 speeds in the early 13 and 14's aren't supported by Diablo,and they have no intentions of supporting the early 8 speeds,which means you'll have to go right to HP tuning ,but the good news is,your 14 is realitly cheap to tune,as you don't need an unlocked PCM. I hope when you say headers,you're referring to long tubes,as shorties are basically a waste of time,and they aren't really good for a truck.You want long tubes on a truck as they generate torque at the bottem end,and carry it all the way through the rpm band,while shorties are more geared towards higher rpm.Same principle as you're variable runner intake manifold,the long runners are for torque,and the short runners are for higher rpm power.Just a quick update.... The truck is running great! Any small mods I should consider? I was thinking of a tune next or maybe a set of headers. something that will not destroy anything... lol....
Best regards,
-Mike
