Global down / global up
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
So I enabled global down on my 2014 RT RCSB and it works great. I also enabled global up, but either it does not work or I'm not doing it correctly
Anyone have any ideas?
14Sport1500
US
I don't think that is allowed due to the injuries it would or could cause. No harm when remotely putting windows down however not being able to see any possible obstructions could be a different situation. IMO
caulk04
Supporting Vendor
Most, if not all, vehicles monitor the amp draw on the windows as a safety feature and will automatically reverse. I don't see why the global up doesn't work, it sure would be nice.
Either way, it doesn't work on any platform that I've found.
Bigskyroadglide
Bigskyroadglide
Moderator
Thanks based on my research and responses here, appears my results are typical and similar to everyone who has enabled.
Hemi395
Cape Cod MA
I recently turned off Global Down because I came out one morning to go to work and found both front windows halfway down. The night before I had my key fob in my pocket while working under the kitchen sink and the button must have gotten pressed in my pocket.
Thankfully it didn't rain that night but I just didn't want to take any chances so I turned it off. Just throwing this out there.....
Bigskyroadglide
Bigskyroadglide
Moderator
Appreciate the response, truck is always garaged, never is outside. Except at work but will take that into consideration
bigred90gt
This is the only reason I haven’t done this yet. I couldn’t tell you the amount of times I’ve set off the panic alarm or locked/unlocked my doors on accident with my keys in my pocket.
DA67Goatman
Ohio USA
I'm going to make a suggestion that may help these guys. Separate your house and vehicle keys and put each set of keys on carabiner. This allows rapid access to the keys and keeps the keys out of your pockets so accidental presses do not occur. I hook them to belt loops, my house keys up front and my vehicle keys on the right side.
yomanne
Cedar Falls, IA
I also can only get the global windows down to work. As a last ditch effort to make the global up work, I changed the "Window Motor Hall Sensors Present" setting and the "Window Motor Type" setting, but still no luck. I suspect you must have the sensors installed for global up to work.
Rlaf75
East Hartford CT
2021 Bighorn
My 11 had the down feature but not up. That would've been totally awesome if they went up as I used it for putting them down all the time. My new 21 doesnt even have the down which totally sucks
AustriaRAM
Austria
Hello,
Is there already a solution to the Global Windows Up problem? It would be great if you could close the windows including the sunroof with the KeyFob (e.g. when it starts to rain).
Many Thanks
PaleFlyer
Charlotte NC
Most "newer" vehicles. My '09 Civic did NOT. And I even think the '14 Frontier I had at a previous job (work truck) didn't. Nor did the '19 NV2000 I had to drive occasionally for a different previous job I don't think.
AustriaRAM
Austria
:eek: My Volkswagen Golf IV already had this feature back in 1999...
I really do not understand what the problem would be with this feature:rolleyes:
kstill
Alabama
I programmed my global windows down. It works with my key fob, but my windows keep stopping. They will go down about an inch, then I have to perform the sequence again and they will go half way and stop... they will eventually make it to three inches from the bottom. Is anyone else having this problem?
