good replacement bulbs
jdeere05
Indiana
what are some bright and good replacement bulbs for our trucks with the quad head light setup with out going to HID?
Hollabakzach23
Lafayette, IN
There's a sylvania that I had on my trick before I went to hids that had great output but it didn't give off that bright white look the hids do soni don't keep em long. The silverstars? I think they were called
dogcar3
2012 Power Wagon
+1
I have these on my truck and the output is good. But I agree that they don't have that bright white of the HID's on my last truck. I didn't feel like modifying my lights so I just stuck with the Sylvania's. You won't be dissapointed if you are coming from the stock bulbs.
quietpeen
2021 TRX
Hellcat
i had the silverstar ultra's on my 05 but they didn't last too long
quietpeen
2021 TRX
Hellcat
beats me. they were much better than the stock bulbs too, but no life to them. I don't think it was wiring or the plugs either because basic cheap stock bulbs lasted much longer
Musclemckeester
Houston, TX
n/a
n/a
Sylvania Silverstars are the best non-HID bulb that I'm aware of. I had the "Ultras" on my last truck...they did pretty good. I don't remember having a problem with them lasting, but I think they were only on my truck a year before I traded it in.
dogcar3
2012 Power Wagon
why didnt they last?
There is a output vs life curve for filament bulbs. They try to explain it a little on the back of the Sylvania packaging. The stock bulbs are designed for max life (hence the weak output), while the Sylvania's (Ultras) are max output (sometimes causing a short life). There are some mid-grade Sylvania bulbs that are a compromise between life and output.
Cthulhu
Calgary, AB
Cummins 5.9
I've tried PIAA and Silverstar bulbs... After 2 year of f'n around with changing the PIAAs every 3-5 months, I put the Silverstar bulbs in. I noticed a dramatic drop in light output. Its simple. HiDs in projectors are the smartest use of your headlight fund. Its next on my list.
Sent from my Tapatalkin' BB 9800
jdeere05
jdeere05
Indiana
damn, i like the hids but looks tricky to much wiring for my likings...lol
Also a note to add. Make sure when changing the bulbs out you don't want to touch the glass of the bulb. The oils from your hands can cause the bulbs to burn out.
Sent from my SPH-D700 using Tapatalk 2
Cthulhu
Calgary, AB
Cummins 5.9
I don't think there's anything too tricky if you go to a reputable dealer.
(Lights the JJ Bat-Signal)
Like I say, I haven't done 'em yet... But with everything I've heard, JJ's name is already on the cheque.
D33k
Las Vegas
Slyvania zxe are awesome, very bright (brighter then ultras) and have a white color 4200k color which is almost a pure white not bad for a halogen. (many oem hids color is 4300k)
I have the zxe on my truck and the ultras on wife's explorer. Both are bright but zxe has nice hue.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
halogens.....well, stink.
I drove home tonight with my halogens. I almost came home and started cracking open a set of lights to put projectors in. Then I looked at the clock, and my awaiting messages. LOL
HIDs. :D
The wiring looks like a mess, but its not bad! Hardest part is getting the headlights out, and you'll have to do that to swap the bulbs to anything else.........so - HID that thing. :D
D33k
Las Vegas
here is a shot of the sylvania zxe 4200k halogen
craigsez
Novascotia,Canada
bulbs
Use your girlfriends/mothers fingernail polish remover or wear rubber gloves..
craigsez
Novascotia,Canada
ddm tuneing..6000 kelvin 55 watt for main headlight and 35 watt for fogs with same kelvin..
GPRADA
