Good Soldering Iron?
4x4Hemi
Edmonton, Alberta
Picked up a butane torch soldering iron today, just tested her out and yeah its garbage, doesnt heat up any solder lol.
So my question is... what soldering iron should i get?? id prefer electric, and id bet that would be the favorite, but still im open to any ideas, so what do you guys think?? Ill be using it to solder some simple truck wires together, nothing big. I dont really want the cheapest iron out there, but i dont need the most expensive haha
So what do you guys use?? Wattage, brand?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Honestly, if you're just doing it to solder some wires on a truck. Go buy yourself whatever they have at your local electronics store. Nothing fancy is needed at all to heat up a wire and melt solder onto it.
4x4Hemi
4x4Hemi
Edmonton, Alberta
problem is man, i did that. and it doesnt work. i bought a $50 torch solder. and it doesnt even melt the solder if i touch it directly to it haha
What kinda wattage would i be looking for then?? 20? 30?
BlackedOutHemi
DFW, Texas
2012 & 2012
****. $50 is what you're considering cheap? I bought an adjustable soldering iron (electric) here at a radio shack for 20 bucks and thing worked like a dream until I snapped it trying to melt plexiglass in half (it worked btw).
4x4Hemi
4x4Hemi
Edmonton, Alberta
haha no that was more then i wanted to spend, i just didnt want a peice of crap one again, i bought a 20$ one and yeah... didnt work at all lol so i was just thinking k screw it ill get a really good one and have it last me a long time
but im returning it tomorrow and getting a different one for sure. im more just wondering what wattage i should get. i can get an 80 watter for like 30 bucks lol
BlackedOutHemi
DFW, Texas
2012 & 2012
I know. Just giving ya a price range and an example. And 140W? That things gonna get **** hot. Lol. Honestly think ya should just go cheap. How often, and on what do ya plan on using it?
4x4Hemi
4x4Hemi
Edmonton, Alberta
haha true that might be way over kill. but ive just been having trouble heating annnnything up at all. doesnt even melt anything lol
I wont use it really over i just have a tonne of wires to solder together, probably going to do 40 of em between my truck and a bike resto. and then after that... it wont be alot lol
BlackedOutHemi
DFW, Texas
2012 & 2012
Go for cheap. On my 20-50W iron any of the setting easily melted solder once you got it heated up
4x4Hemi
4x4Hemi
Edmonton, Alberta
cool man, i just didnt know what wattage to get, soldering sucksss with a ****** iron hahaha takes way longer
Rock$tar
Newfoundland, Canada
Cummins 6.7L
What kind of solder are you using? Purchase the thin stuff for electronics. .02 dia and sn62 alloy. Makes life easier and you dont need alot of heat so you dont risk burning up electronics as easy. Just alittle annoying with it having to feed so much more into a wire because of how small it is.
Posted by my Droid
Stangshcky12
Oshkosh, WI
5.9 Cummins
I like using flux cored solder too
If you can adjust the temperature of the new iron its a plus too
I have a 180W gun and a 30W iron that has 3 different tips that was $9 that I like better then the gun
TexasRammer
College Station, TX
Could be the solder. I know when I first got my little cheap soldering iron from radio shack it took forever to heat up and mept the solder but it works a lot better after a couple usea
nussdawg395
PA
5.9 Magnum
I'm also a fan of the flux core solder and using the smaller thinner solder. I have a cheap-o iron that i got in a kit like 6 years ago that still works awesome and its been used and abused. Ive also have crap solder that was too big and took forever to get it to melt. Try new solder before a new iron.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I've gotten spoiled with the irons I've used at school that I've come to hate guns lol
WhiteExpress
Midland, TX
I got a 40W unit from Radio Shack, can change the tips on it. Works like a charm.
I also use flux core wire.
wingnut
Da Thumb
5.9 gas
Lots of good advice here. Alot of the problems folks have with soldering is the way they solder. We aren't doing circuit boards here, so a little heat isn't bad. For a board, about 35w. Go higher if you want to solder wires. Flux-core solder is fine for automotive. the thing is, alot of folks want to lay the solder onto the wire, or object. The key is to heat the object and let the solder flow ONTO it! A glob of solder on the tip of your iron will not stick to a "cold" item. You need to heat your target, and then apply the solder. This will produce a "wicking" effect that will draw your solder to where you want it. There are lots of Youtube videos to help you with this.
noraa73
