That’s a tough one, it depends on how you drive it and honestly luck. Some people have had success with Shardon’s built 545’s, there are a few people trying to test out some ATS built 545’s but it seems to be a fiasco at the moment. My trans lasted very well for a about 6 months behind my stroker before I swapped trans to a built 46re with a reverse pattern manual valvebody. Ran me about 3 grand and I truly think I have a trans that should give me zero problems for a long time. I have some buddy’s running them on supercharged/turbo charged stroker drag trucks right now and they are holding up great. Only problem is the gear ratios suck, I’m rehearing my rear end right now. Your trans may last for awhile as long as you don’t do an hard downshifts out of overdrive. Seems like 1-2-3 gear is pretty strong in a drag racing situation, it’s flooring it from ~50 mph that destroyed the overdrive clutches.
I Bleed Ram Trucks
