Got some good news from the dealer
dirtystick
Indiana
4.7 Magnum
So I went into the dealer for my oil change and had them run the VIN for a build sheet. I got excited when I saw it!!! I was worried I was going to have 3.55 gears, but this is my sheet!
3.92 Rear Axle Ratiocd:naughty:
Anti-Spin Differential Rear Axle
Corporate 9.25 LD Rear Axle
Trailer Brake Assist
Most probably don't care, but I was excited so wanted to share.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
nice!
shadow11
Banned
Houston TX
You can do a real burnout since you have the lsd lol
ramhunter9
P-Star Jeep Wrangler
nice !
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Excellent..
HemiBabe
DFW
Oh yeah! I have the same thing in my truck! Rock on!
Btw, I don't know if your truck has it, but inside your glove box there should be a sticker from the factory and it should say that exact same thing :D
4X HEMI
Lancaster County, PA
You could have looked at the rear diff and looked at the plate mounted on it that tells you the gear ratio.
Should also be on the inside of your glove box.
D
dirtystick
Indiana
4.7 Magnum
Negative, checked both places. No metal tag on the rear diff and no white tag in the glove box. Checked both places multiple times.
Shiloh 24
Kansas
5.9L gas
Cool beans, just make sure the rear end doesn't implode on ya because of the little c-clip in there that causes havoc.....
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Don't be scaring the guy shiloh. lol Good to hear you have a lsd. But where is this factory brake controller??
4X HEMI
LOL .... Been there, done that! .... Dammit and Dodge is aware of the problems with the rear and will not do a recall on them!
D
dirtystick
Indiana
4.7 Magnum
I haven't looked for the brake assist yet, but the trailer hitch has a connection setup and I have a brake assist cable in the truck to put in the setup.
The build sheet has a ton of gibberish I have no idea what it is suppose to mean.
southalum
