Grill removal
donno21
Las Vegas Nv
Cummins Diesel
2011 RAM 2500 Cummins 4wd Crew Cab Been told grille must be removed for access to wsw pump. any one done this? thanks
laramieram
I've never changed my wsw pump but I have had the grille out to do my plugs (so i had room to stand on the bumper). Taking it out takes about a minute, it was either 4 or 6 bolts across the top. It just snaps in at the bottom.
MaizeNBlue
6 push screws on the plastic cover.... 4 10mm screws on the top,
blrmkrl83
Iowa
Here's a video taking off the grille on a 1500. https://www.youtube.com/watch?v=gtD3190y8fc
There are I think 6 clips you pop out on the radiator cover. Then there's 4 bolts on the top of the grille. 10mm is the socket size. The 2 middle and the 2 outer bolts have different threads. The bottom of the grille is held in with clips. You just have to kind of lift and pull on the grille to get those out. This is on a 1500. I can only assume a 2500 is the same.
