Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
czervika
Punta Gorda FL
Hello guys , i'm looking for a suggest for my leveling kit .
My 1st upgrade was terrible !!!
I placed the rough country kit in both the front and rear springs raising 2.5" and 1.75" and the result was aesthetically very good but the ride became terrible.
Now as a further upgrade I would like to replace all the shock absorbers with bilstein 5100 but without using their leveling because I don't want to preload the spring but I want to place spacers on the upright at most 2". I read the 3d at the beginning and I know that you would have to stack 2 different leveling kits but setting the bilsteins to stock mode and only using the 2" spacers above is that a terrible idea?
With this solution can I keep the ucas stock or will I have to change them?
The solution of using the 2.1" level of the bilsteins scares me as by preloading the spring I think I will have a guide very similar to the one I have today and it is really bad ... I feel vibrations everywhere even on the accelerator pedals and brakes and feel every slightest pothole in the road.
I know how you feel about space strutters but I'm very confused and I hope you will help me find the right setup for my truck
"Stacking Leveling Kits"
The answer is no! Again, this is one of those things where I don't care what your buddy told you or what you think… there's no if, ands or buts. You cannot stack a spacer on top of Bilsteins to get additional front end lift. Typically you do not want to lift your front end any higher than 2.8” without doing a control arm and front diff drop. You will be putting your entire front end out of spec, your control arms and CV shafts will be at ridiculous angles which will be wearing everything out very fast and I doubt any shop will be able to align your front end. If you want that much height you need to start looking into lift kits rather than leveling kits.
You're not preloading with the Bilstein's perse, you're moving the mounting location of the spring bucket up further in the shocks travel. So in essence you're limiting or losing vertical upwards travel, gaining downwards. That is until the spring binds. You're not gaining overall travel just where it occurs in the shocks travel if that makes sense.
Either way with a level over 1.8 I'd get new uppers for a level. Or just bite the bullet and install a lift that has new knuckles and be done with it.
minotto
italy
Hello , why you "report"my post ? i'm looking for help to setup my ram because its my 1st experience with a truck .
Please send me pm if i wrong some rules ...
Thanks
D1DAVE
HALLETTSVILLE TX
HEMI 5.7
This is a great thread. Its given me the info I needed to move on with my little lift project. Thanks!
jrsmith66
Atlanta, GA
Spent months trying to decide on tire size. Didn’t want the stuffed look of a 35x12.50 and more risk of a rub. A lot of recommendations for 295/60r20 with stock rims but not a ton of pictures out there, so I figured I’d put mine here. Bilstein 5100s at 2.1 and 295/60r20 Hancook Dynapro X/Ts (~34x12 according to their spec sheet), no spacers. Exactly the look I was going for. No rubbing at all. Bottom of truck right behind front tire and front of rear is dead level, half inch lower on the front wheel wells which I expected when I measured.
Jeepdreamer
Kentucky
Phew…. That was a LOT to read through! Thank you Brandon for all the valuable information and simple-speak!
If I’m digesting all this correctly, does this sound right?
2012 1500 QC bighorn 4wd
Want to ditch the 20s for 17s and will be running 35x12.50x17 BFG MTs
What will be needed is:
2.5” spacer
17x9 0 backspacing
Alignment
(Nothing required for the rear)
Does that seem correct to keep rubbing to a minimum (or trimming). This is a daily driver street truck with occasional light work around the house (dirt and grass, nothing crazy).
Sebav
Poland
Hi,
I have allredy lifted my 1500 from 2017 on the spacers, but suspension is too soft. I am interesting with 5100, Ironman Foam Cell or 6112. Anybody can compare this type of shocks? Could i install for example just shock from Ironman on stock spring?
I saw on youtube that Ironman is in medium class and 5100 i low budget but I am not sure about ride quality.
Hemi395
Cape Cod MA
Hi,
FWIW Ive had 5100s with the stock coil springs for about several years now and they have been great. Ride is a bit stiffer than the stock shocks but nothing too harsh.
I have no experience with the 6112s or the Ironman shocks tho
