Gun Mounts
Sasquatchtdg
Moncks Corner, SC
I need ideas for pistol mounts. I was thinking of some kind of holster, double side taped to the inside of the center console. I've seen the magnetic mounts but it's not legal in my state. .40 Springfield XD is my truck gun.
bryce88
Utah
What exactly is not legal about the magnetic mounts? Is it just because the trigger is open? I ask because you could do a magnetic mount in conjunction with a trigger guard holster like this:
james.price.58
U.S. Navy Veteran
I have the Alien Gear holster/ Cloak dock combo. I love it! I also carry a Springfield .40 (when it's cool enough to wear a jacket) and a Colt Mustang for the warmer months. The holster allows me to switch out the shell and use the same accessories.
Dinky
Oregon
Just type in "pistol dash mount" into Google. About 50 different types with links to each one.
CincyCuda68
Ohio
I use the Alien Gear shape shift, does the dock work with that? My carry gun is the XD 9mm or my M&P 2.0 compact, that would be a great location if I could stop it from sliding around down there.
james.price.58
U.S. Navy Veteran
Not sure...I know its designed as a system but it seems like any paddle holster would work to some extent. With the cloak holster, it's very secure and no movement whatsoever. I believe any other paddle holster may work but would probably slide around some.
CincyCuda68
Ohio
I tried my paddle holster from my shapeshifter kit and it was too loose for my liking.
james.price.58
U.S. Navy Veteran
Yeah, they're a compromise. Easy on/off if you're taking it off several times a day.
misfit77
I carry my M&P Shield in n the "ash tray". Not necessarily a quick draw, but it's quicker than trying to reach into the center console.
Sent from my moto g(6) using Tapatalk
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
In South Carolina it has to be "contained." In a glove box, center console, trunk, etc. It cannot be open access like the under the dash magnetic mounts, sitting under the seat, in the door pocket, etc.
CincyCuda68
Ohio
Is that just for transporting? In Ohio you need to have it contained unless you have a ccw, then you can have it wherever you want.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Sounds to me like you don’t have a state-issued permission slip to carry there in SC- otherwise, you wouldn’t be worried about where or how you can carry your pistol in your vehicle.
corneileous
Podunkyville, OK
I use the gum Creek setup. Love it.
http://www.gumcreekcustoms.com
Which setup you have? I bought Gum Creek’s brand new console holster for my full-size Beretta Storm .40 but I had to do a little bit of modification to it for it to fit tightly down there on the side of the console but I sure like how it turned out. 8bcd88517776071b0911ce42c6c53c15.jpg
corneileous
Podunkyville, OK
I’m thinking he doesn’t have a permit because thats how Texas is, if you don’t have a permission slip. They allow your vehicle to be an extension of your home but without a permission slip, you can’t carry your gun out in the open.
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
I have my Concealed Weapon Permit. I want a mount that keeps it out of sight and out of the way, but easy access when needed. Yes without a permit it must be in a contained area. But in the event my wife is driving, who is not currently a card holder, i don't want her catching a weapons charge.
"With a permit from South Carolina or other recognized state, you can carry a loaded concealed handgun in a vehicle on or about your person."
Just asking for mounting ideas fellas, not a legal class. If i don't see one i like i will make one and do a write-up in here.
corneileous
Podunkyville, OK
I honestly don’t know where you’re going to find such a mount that’s going to satisfy those needs. I wasn’t trying to be snide or smart-assed with what I said but at the time that was the only reasonable assumption as to why you’re wanting to mount a handgun in a vehicle, but keep it outta sight which pretty much defeats the purpose in all its entirety of mounting it in such a way for easy access. If you’re worried about your wife getting in trouble if she was to get pulled over from your gun being mounted in an easily accessible location, then all you have to do is just make sure that you put the handgun in your glove box or in your console when you’re not driving the vehicle. Or.... and probably the best alternative would be that you could get your wife to go get her carry permit and then you’d not have to worry about it at all. Then you’d have a lot more option to mounting your gun that in a location that will benefit you the most in the time you may need quick access to it.
Dinky
Oregon
OR just take the gun with you and not leave it in the car....
corneileous
Podunkyville, OK
Or just not even leave it in it’s easy access location at all. Really don’t want to leave your gun out on the open inviting someone to bust out a window and cause you to have a really ****** day. Lol.
That Gum Creek console holster I have really only gets used while on long trips. It doesn’t get left there out in the open. It either goes with me, or on rare occasions, it gets stored in the glove box or in the center console. Usually when Im driving long distances, my little Ruger 9mm stays in my front hip pocket in its pocket holster and the big Beretta os down between my knee and the console.
CincyCuda68
Ohio
Exactly, get a gun safe for the console, so when you go into places that you’re not allowed to carry you can lock it in your truck, then have it in a quickly accessible mount while driving. You really shouldn’t leave it in your truck all the time, you are asking to have it stolen.
gville35
