Hard-starting when (really) cold
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
So, as much as I have done to winterize my truck, Iowa winter once again does it's damndest to make things as miserable as possible.
Here's the deal. If the temperature is around freezing, the engine starts no problem. However, if the temperature drops to the teens/single digits then engine will fire but die right away. If I start the engine while holding the throttle just a bit, it fires and runs just fine, but as soon as I let off the throttle, the idle fumbles and the engine dies. If I hold the idle high with the throttle for a minute or two and let off, the engine will idle just fine, though sometimes it will start fumbling between a few and several hundred RPMs.
If the engine is hot, it will start and idle without any problems at all. So the problem seems to exist as long as the engine is cold, but completely disappears (for now) when it is at operating temperature.
My first thought was the IAC, but I did replace the damned thing earlier this year.
It's negative wind chills and blowing snow for the rest of the weekend here, so there is no ****ing way that I'm crawling around under the hood fiddling with things now. I'd just like to start compiling a list of things to check when the temperature at least comes within a few degrees of the freezing point, though I might be waiting some time.
I hate Iowa winters...
MADDOG
Living in a Firepit
Do you think you might be suffering from a little bit of fuel system freezing?
Do you add any fuel system anti-freeze to your fuel, such as "Heet", in the winter?
crazy_luck
Minnesota
Grasping at straws, but I did have a car do almost the same thing - turned out the coolant was starting to gel up and dragging the water pump too much, bogging the engine down; after a couple minutes, the coolant was no longer gelled and there was no extra drag. Just had to tweak the coolant mixture for colder climate and problem was gone.
MADDOG
Living in a Firepit
Good info. I remember this happening to me in Wyoming now that you mention it.
I added a block heater and the problem went away.
Yeret
Yeret
5.9 Magnum
The only fuel additive that I occasionally use is Seafoam. I usually dump in a can when the temperatures start getting cold (Fall) and when the temperatures start getting warm (Spring).
Interesting thought on the coolant. I replaced mine earlier this year and whipped up a 50/50 mixture using distilled water of course. Perhaps I can pop the cap and take a look at it later.
Sport
5.9 Magnum
Do you have an engine block heater installed? They are recommended anytime a vehicle is being regularly used in sub freezing temperatures. I think you could get a simple one for ~$50.
crazy_luck
Minnesota
Yep, there are OEM variants for the 2nd gen Ram for about $50 that replace a frost plug.
Or, you can get a universal magnetic one that just attaches with a heavy duty magnet to the oil pan or block. Down side is you have to partially crawl under every time, but it's cheaper and just as effective.
https://www.amazon.com/Kats-1160-30...2085674&sr=1-1&keywords=magnetic+block+heater
dapepper9
Iowa/Nebraska Border
5.9L V8
I'm in the same -26 ******** on the other side of the state. 50/50 is good for -20 and with the way the wind picks up, on a full full i go 1 jug 100% ethylene glycol and do the rest 50/50. Never have an issue
Yeret
Yeret
5.9 Magnum
Well, the negative wind chills have returned, however oddly the problem has not returned. The only difference is that I've been pumping Quik Star gas rather than BP. No idea if this could have been a factor or not. Guess we'll see if everything stays okay.
One thing's for sure though. I either need a different battery or a new starter next year. I've got a brand new O'Reilly's Super Start Extreme rated for 770 CCA and it really struggles to turn the engine in these temps. I don't expect a battery to be as strong in -20 as it would in 85, but I'm honestly concerned that I'm not going to get many seasons with this one before problems start. Or perhaps my 20-year-old starter has just become such a dog that it's making things harder than they need to be?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I'd bet on your coolant if its hitting temps as low as over here in michigan. I had to get my jump pack out to start my loaner truck, 98 ram 1500 5.2l. The guy ran 50/50 and when I pulled the cap off the radiator is felt like that slime stuff that used to be in the commercials as a kids toy. It was a good -20 out, I think I crushed my balls when I leaned my chest on the fender to jump the frozen battery.
Edit: Didn't see your last post. It may be that their gas was gelling up. Wouldn't be the first time a gas station has pumped bad gas. The Shell stations around me are known for not properly changing over to winter fuel, as a result if we get a bad cold snap early in the year, or you go to a station that doesn't get a lot of traffic, and you're in for trouble. None of the marathons or stations they own have a problem though.
SHOOT2KILL
2015...2500H.D.
One of my chevys had the same problem. Code was for M.A.F. sensor. Put an aftermarket (Autozone) in and had the same problem. Replaced that with another Autozone part. Still had the problem. Replaced the Autozone maf with an OEM AC/Delco....problem fixed
Rgesse
