Has anyone upgraded their side view mirrors?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
I have the standard heated power mirrors.
Can anyone confirm if the wiring will support the tow mirror upgrade with turn signals? Or will I just retain the power to adjust and heat the mirrors?
RTS001
New Orleans, LA
I've been researching this, so far I have not gotten a clear answer, but most seem to be leading to NO. There is a missing/or separate harness for the turn signals. I haven't given up yet though....:superhack:
iam_canadian22
northern ontario
You will only retain the functions your original mirrors have regardless of what features new mirrors have, i dunno if its something dealer can reflash to work, no one seems to have looked into it that much
Shawn226
Mercer County, Pennsylvania
3.0L EcoDiesel
It depends on the dealer you go to. I bought the tow mirrors, I retained power heat, but I asked them about re flashing it and they looked at me like I was asking for 100,000$.
bskl76
Bako, ca
5.7 liter Hemi
Side mirrors
I know for 2012 it can be done it was confirmed by rf member. I got to believe newer rams will work cause we still share a lot of same parts. First u have to take off door panel & see if u have the wiring for it. After removing door panel u will see a wire from side view mirror going to a wiring module on door panel. Right under the side mirror plug there should be a empty pin out plug. After u install new mirrors u need dealer to flash.
