having a electrical issue need input
zwilhelm
1997 ram 1500
i have a 1997 dodge ram 1500 4x4 i just changed the alternator last week bc gen light was coming on but now when i have my headlights on my volt gauge drops same when i have the heat on when i come to a stop headlight dim out when i start to drive it goes back up to 14 anyone have any ideas
sbarron
Wasilla, Alaska
Try a different/new battery, make sure the connections to it are clean and tight.
alanack6795
5.9L6
The voltage regulator is in the PCM of the truck. Meaning the computer controls the charging voltage.
If your lights are flickering while driving, and you know the alternator is good (it could be bad out of the box). The PCM most likely is the culprit
You can wire up an external regulator if you dont want to swing the $$$ for a new PCM.
A voltage regulator and plug can be purchased for less than $30
http://www.cumminsforum.com/forum/a...ernator-voltage-regulator-17307regulator2.jpg
