HAVING PROMLEM WITH RAM 2020 TAKING GAS ITS IN SHOP THEY CANT FIX ANYONE ELSE HAVE THIS PROBLEM
chawk
california
HAVING PEOBLEM WITH 2020 RAM 1500 TAKING GAS, IT WONT, IN THE SHOP THEY CANT FIX THIS, HAS ANYONE ELSE HAD THIS
Turn the CAPs lock off while you type for starters.
You might want to find a different shop as if fuel won't go into the tank it's either the filler neck vent or the rollover valve in the tank. It's probably the later which means the tank needs to be replaced.
Dodge 1500 4X4
Rochester, NY
X2 have the tank replaced, A known issue they know about it, the pump filler nozzle in your state is the problem, with the short neck in the fuel tank.
