headers install
tantore
texas
hi guys can any one tell me if a video is available on haw to install headers on a2012 ram 1500 5.7 l. engine any help will be great thanks Ray
whetrick1
Check YouTube
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Which headers are you installing? Are you 2wd or 4wd?
This is a pretty straight forward install though. If you can take the stock manifolds off, then you shouldnt have any trouble putting the new ones on.
DILLIGAF
Canadian Forces
Canada
JBA's fit like ****, Avoid them if you can.
T
tantore
texas
hi mat i want to install the shorties that i want to buy from you in the next few weeks will be in touch thanks for the feed back to all
nickpohlaandp
Lake Charles, LA
Headers fit fine, JBA's Y-pipe fits like ****.
I wouldn't waste your money on shorties. Spend it elsewhere or get long tubes.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
I wish people would stop just automatically saying this. The people that say this have obviously never looked a set of stock manifolds, Ram must have spent $5 designing them, anything is an upgrade over stock manifolds.
I installed a set of shorties on my truck and it made a noticeable difference in the performance.
DILLIGAF
Canadian Forces
Canada
Actually, Having to dent the pipe for the steering shaft to clear is **** ! And Im not the only one that had that problem, :puke:
Never read anywhere ARH having that issue.
So I stand by my first comment JBA's are ****. And I regret not waiting a few more paychecks and savings for ARH.
Csanders1992
Best advice I have is to pull the front plastic wheel well liners out. That's how I installed long tubes on old Chevy and it made it a lot easier
nickpohlaandp
Lake Charles, LA
This is a no-brainer, must do. It will save you a lot of busted hands and time. It takes 5 minutes to do, do it.
On my LS powered truck everything was easy enough to access from the top. On the Hemithe best advice I ever got was to remove the plastic wheel wells.
