Headers. Will they work?
Tcpriem
He no 5.7
I recently found out my 2013 Sport has a manifold leak due to a broken bolt. Took it in for warranty and found out it was a Canadian truck (no warranty).
Needless to say, the ticking is driving me nuts. I can't stand having what I consider a "nice truck" when it sounds bad?
My question is: what is everyone's personal opinions on headers for the 5.7 hemi?
I would rather just replace the manifold with headers since I'm going to be spending a decent chunk of money anyways.
I have found cheaper $300 headers in eBay. Along with OBX and other brands.
Has anyone ever used the eBay headers? Any luck? I know what you all are thinking... just looking for some input.
Thanks all!
T
Tcpriem
He no 5.7
EBay Headers
http://m.ebay.com/itm/Dodge-Ram-1500-2009-2015-5-7L-HEMI-Long-Tube-Stainless-Performance-Headers-/332255455430?fits=Year%3A2013%7CMake%3ARam&hash=item4d5bf7e8c6%3Ag%3ACfkAAOSwa%7EBYQNA3&_trkparms=pageci%253Acf6e7688-6253-11e7-ada9-74dbd180c205%257Cparentrq%253A1835f65c15d0a9e86a9d22d6fff1f841%257Ciid%253A4
daveray9
Subscribed...
Sent from my SM-G920V using Tapatalk
tantore
texas
Hi guy your question about headers i have a 2012 5.7 ram 1500 and have the shorties bbk. Headers and i like them no problems jet as of 1 yr. Ago cost $414.00 for the ciramic coated ones thru moes performance i hope this will help
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Feel any low end torque loss with shorties?
Robocop_9
West Virginia
I'm also running bbk shorties with full bolt ons and 321 gears. I don't notice any loss in the bottom end.
Burla
2010 Hemi Reg Cab 4x4
Machine Shops can fix bolt issues, with either headers or stock manifold.
crackerjack1957
Thanks, you probably have 8-speed trans with that 3:21 gear, would be more noticeable with 6-speed.
Bluto
I had the same "Canada issue" so I did BBK shorties and have not noticed any loss of power.
By the way it was up to the dealer to disclose to me that is was a Ca truck and they didn't. So I pressured them and they paid the labor for the install.
T
Tcpriem
He no 5.7
Thanks guys.
I was quoted $550 to replace just the bolts on the original manifold and that was only for the broken ones. I figured if I installed long tubes or shorties, that I could spend right around the same and know the bolts are going to hold up.
Any input on the eBay headers?
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Thanks guys.
$550 is outrageous for a few bolts. As for the ebay headers, only a few have tried them and they all failed within a few months. Usually the welds break at some point. If your looking to just fix the truck I would buy the bolts and do it yourself. For a performance bump get LT headers; cheapest I would go is JBA but you'll need a tuner And a custom tune. The shorty headers wont be anything worth it; blackramhemi did shorty's and they dyno 8 HP. Not worth it in my opinion.
Ndziy
Edmonton, AB
if you are patient and have a bit of mechanical aptitude you can find that bolt and drill it out enough and get a left handed drill bit to catch the hole you just drilled and it will come out easy peasey!!! but for headers i got the long tubes and they are a big difference in sound and performance, if you just want that fix to stop the ticking go with shorties and i would suggest JBA short tube headers, they are a very nice quality and the price is fair. at the end of the day you get what you pay for
T
Tcpriem
He no 5.7
You guys rock. I knew $550 was outrageous for the bolts and that's why I'm exploring all options.
It just made me question if I just replaced the bolt, what are the chances it happens again and I run into the same problem? That's why I asked about headers.
Sounds like shorties are a good "fix" without much power gains. Are people needing a tune after the shorties due to increased airflow or just the long tubes?
Robocop_9
West Virginia
I just put shorties on and I run a hemifever tune. My tune did not change from manifolds to shorties per Sean. With long tubes you could throw codes so the tune will fix that. Get the oem gaskets and 6.1 bolts. You'll never have to worry about bolts again.
N1ck
Regina Sk
Did you notice any power gains?
Robocop_9
West Virginia
I have full bolt ons so it's hard to say how much gain the headers alone gave
