Headers???
BEAST19
Any suggestions on headers??? I have a 2015 ram 1500 with the 5.7L e23089de21b54b287a1a53d78540d6ba.jpg8 speed . K&n intake and mbrp exhaust. Running Hemifever tune off diablo i2 ... Looking to get the most out of it. How much should I expect to b charged for install and what gains should I expect????
Robocop_9
West Virginia
Go long tunes and y pipe for the most gains. Moes performance can hook you up.
BEAST19
BEAST19
Thanks how much does it cost for install any.idea??
Gamester
Get long tubes and a y-pipe from ARH and good to go. Install price will vary a lot depending on your area and shop, but will probably be around 500-700 as headers in general can be a major pain in the rear to install.
Txhemirt
Lubbock, Tx
Running jba headers and oem gaskets with y pipe. No cats. I had them installed for around 450. What hood do u have rivers. Looks sick. Got the LTs from Moe's
BEAST19
BEAST19
Whst do I do for cats? I see options that have long tubes and headers with or without cats..... Looking like 1600$+ from.moes without headers ...
BEAST19
BEAST19
Do I get them with or without cats ? Without them will it cause me to fail inspection ? I live in NY
Txhemirt
Lubbock, Tx
Depends on your state emission laws, you will have to look into that. What hood do u have and where did you get it.
CTD
Southwest, VA
Just ordered a set from Moe's yesterday. I got mine with the cats. I don't have any kind of inspection, it was just my personal preference.
If they do a visual inspection or sniffer where you live then they can and probably will fail you.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
I am in CT.... I did ARH long tubes with high flow cats...I also have the magnaflow 16869 cat back exhaust kit.
One recommendation I will tell you is get the headers and y pipe ceramic coated inside and out! This is way to go...cost about 300/375 but totally worth it for heat and flow....once these babies are installed you don't want to screw with them. I also used new oem gaskets and stage 8 locking header bolts.
My ram dealer installed them for me...ARH bolt right up...you just need to adjust the oil dipstick. They charged me $500. Well worth it....then get hemifever to tune it for you....next clutch fan delete....and 180 stat with the ATI dampener pulley....really wakes truck up! I just ordered a pedal commander that came in today....got a new tune from Sean so I can now adjust pedal response 36 choices on the fly. He has a special on these $269. Do the headers right the 1st time it's pricy but worth it...I have had them for 2 years now. Oem manifolds suck a$$.:superhack:
Captain_X
Are you dead set on headers? Why not a cam?
BEAST19
BEAST19
Thanks for the info!! Where do u get em ceramic coated? Arh doesn't sell them done already ??
BEAST19
BEAST19
Can u send me a link on the OEM gaskets and locking header bolts
Hipps2000
Hemi 5.7l
No ARH does not sell coated. I got mine done locally but many send them to jet-Hot to get them done. The Oem gaskets got at the dealer. Google stage 8 header locking bolts Ram. Bought off amazon for $50. I did buy headers and tuner from Matt at Moes. I would highly recommend you get them coated inside and out....mine still look new...it protects them...better flow...and reduces engine bay heat.
CTD
Southwest, VA
I thought stage 8 locking bolts come with ARH headers?
Hipps2000
Hemi 5.7l
No you have to buy the kit just google stage 8 hemi 5.7l about $50
predat-r
4.7 v8
Yo tha truck looks beast man really luv how it all comes together.
Sent from my SM-N920P using Tapatalk
joshhhh
