Tbear44
Trying to figure out what’s wrong with the headlights on my 2017 RAM 1500. These are the steps I’ve taken.
Any other suggestions or tips?
- all lights worked
- passenger side head light went out
- replaced passenger side headlight & high beam
- replaced driver side headlight & high beam
- Rear lights are fully functional
- Passenger side headlight turns on when truck is unlocked
- Driver side headlight DOES NOT turn on when truck is unlocked
- Passenger side headlight turns on automatically when dark
- Driver side headlight turns on automatically when dark
- Passenger side high beam works
- Driver side high beam DOES NOT work
- Passenger side turn signal works/flashes
- Driver side turns on and stays on while the car is on. DOES NOT flash
- Dash message says “left turn signal out”
- Disconnected negative terminal on battery for 1hr and reconnected. Message still comes up
- Not sure if any fuse is associated with headlights
