Headlight assembly
Kiethw
I am new to this forum. Have a stupid question. I am replacing the passenger side headlight assembly. I am having trouble getting the headlight to snap into place. Everything lines up but when I go an push the top of the headlight into place where the rounded stud snaps into the clip it will not pop in all the way. I have pushed so hard that it is hitting the fender. Is there a trick to get the stud to snap into the clip. This seems to be cut and dry but it will not pop in. I'm in a time crunch as I have to drive to work tonight and I need to have the assembly in.
Thanks
spuz
4.7 l v8
forgot what i did but it went in. jostling helps. happened to put one in tonight. you have to pull the old fastener out and throw away as a new one comes with new light.
