Headlight issue
Toeknee
Hell all, wondering if anyone else is having issues the passenger headlight going out. Noticed it yesterday changed bulb and when tout again. Don’t know if I should buy another bulb or just get a new headlight assembly. If so headlight assembly, any recommendations. 2014 1500 tradesman. Thanx
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Won't be assembly. If bulb didn't fix it connector could be bad. Try some dielectric grease on the connector.
Sent from my SM-T350 using Tapatalk
Reelinbass
Ontario
Hi. Had that issue on my 2010 Dodge Ram 1500 drivers side. Bought a new connector with a section of wire. Had to cut about 10 inches of wire off. It's a common issue. Wire gets hot and goes bad. Been good ever since
Reelinbass
Ontario
Hi. I have a 2010 Dodge Ram 1500. My headlights were not working the other night. Went to check them in the morning. They were working. Last night went to go for a ride. Headlights did not work. I rotated the switch from Auto to on headlight. Still nothing. Anybody hear of this? Thank you
joshhhh
