Headlight replacement questions
AngryRams
AngryRams
Phoenix
Yes. It fit. To make that DRL to work You just need to connect a wire to the fuse box
Thanks.
Can HID's fit in? Or standard bulbs? I currently have LED in my truck but they act funny, and go out @ random times.. not like a flash.. but actually turn off.
I do not have factory projectors or day time running lights.
You could also add the dedicated DRL circuits. I added them to my '15 Outdoorsman, and programmed them with AlfaOBD. On a 1500 you'll want to check if the harness under the fuse box has these two circuits populated:
PIN 8 - LEFT DRL LAMP DRIVER
PIN 23 - RIGHT DRL LAMP DRIVER
Then contact M² Mods for the extended length pigtails for the DRLs.
OnSale
5th Gen Crew
Philadelphia, Pa
will these fit and are they plug and play?
https://www.carid.com/spyder/black-...2-sb-bk.html?singleid=2065153778&url=90748630
DO NOT BUY THEM FROM CAR-ID!!!!
These exact same lights are sold on amazon and eBay for around $250-$280. Don’t waste $200+ dollars just to buy them from CarID when you can get the identical lights from eBay. And yes, they come in the official Spyder box, same exact thing.
Kalill Nieto
Fort Lauderdale
Thanks.
Some of this aftermarket headlamps wont recomend to use HID because the heating can damage the reflector inside of the projector. Some plug and play Leds has bad output. But you can find a good set of Leds for sure. In my case I replace both projectors for bi-leds.
