Heat - air flow issue
daveray9
In the last week, if I use the remote start (factory) and have left the heat on only cold air will blow out. Same with if I start the car manually and heat was already on, but if I turn it to cold.. then back to hot it comes out hot. Also seems like their could be an airflow problem, could be in my head. But when I put it on in the Wrangler I own.. it comes out FULL BLAST. When I put it on the vents in the Ram.. on high.. doesn't seem to be flying out that fast.
Anyone have an issue like this or any ideas?
Another weird thing, when I use remote start I usually leave the heat on the Floor.. and even with it on the floor it now starts blowing out of the defrost and then when I put the key in and turn it to ignition it changes back to floor.
Its a 2012 Sport so no longer under warranty.
