Heater Blowing warm not Hot
Taran Tavares
Indiana
Hemi 6.4L
Hello,
I have a 2015 2500 6.4L. Lately my heater has been blowing warm, but not what it used to be. A couple weeks ago I had to replace thermostat, water pump, radiator. I haven't had a chance to look at the heater core. The coolant gets around 215 degrees, and the system should be burped by now. Any thoughts?
HDGoose
L6 Diesel HO
Check the flow through the heater core. My 2013 was clogged because it simply is a bad design. Heater cores should be flushed every year or two to help prevent blockages.
Perhaps tryin to reverse flow your core will help flush it.
But for only $52k I fixed that issue with my 2013 2500 with a 2020 RAM 3500.
T
Taran Tavares
Indiana
Hemi 6.4L
Okay I'll have to give that a try thanks! if only I could afford the new one I they look good!
three D
alaska
I flushed the heater core about 20 times about a 2 gallons each time into a bucket and flakes of junk every time. my heater is working better still a not that warm on the drivers side. 2014 2500 6.4 105000 miles
T
Taran Tavares
Indiana
Hemi 6.4L
Yes I'm going to try flushing the core when temps get above freezing. The thermostat, radiator, and water pump have all already been replaced.
Kamikowski
