Heater problem wirh steering wheel
Kazo90
Hi guys, I have a ‘16 ram sport and I would lime to know if you ever heard that when I turn my steering wheel left I feel like the heater is getting more hot and when I turn right it’s getting colder.
Thanks
chamolie
2016 SLT
Cummins 6.7
It sounds like the clock spring.
If you are handy, you can remove the steering wheel, remove the clock spring, open it up and check the solder connections on the ends of the coiled wire.
There are YouTube videos on how to remove your clock spring and watch videos that show and explain how it works.
Guido2112
Are you referring to the heated steering wheel itself changing temp. or the main heater in the dash changing temp when you turn?
