Heavy Duty Alternators and Starters
ramhunter9
P-Star Jeep Wrangler
Heavy Duty Alternators and Starters by MEAN GREEN , brought to you by DBTC
Running allot of power and that stock ALT and Starter cant handle it ?? When that sub hits does your lights dim or flicker ....you need more power . Running allot of auxiliary power , lights , winch , compressors ? This is for you ....
Mean Green Gear Reduction Starter $355 SHIPPED NO CORE !!
The Mean Green Gear Reduction Starter is the answer to all of your starter problems. The Mean Green Starter provides 100% more torque than an overweight stock starter. With a 4.4 to 1 gear reduction, roller bearing support, and an integrated solenoid, the Mean Green Starter can crank any engine no matter how high its static compression.
Superior Design
Easy Installation
1/3 Smaller Than Stock
100% More Cranking Power
300,000 Mile Life Expectancy
No More Hot Start Problems
2 Year Unconditional Guarantee
No Core Required
The Mean Green Starter's 3" tool steel driveshaft is supported at both ends by bearings. The stainless steel pinion shaft is externally splined to mate with the larger diameter, internally splined driveshaft. Even the armature in the high-speed motor is supported at each end with bearings. All totaled, there are five bearings in the motor and gear assembly. That's one reason we include a 2-year Warranty at no charge on every starter, (Commercial and Racing applications carry a 1-year warranty). Another is the heat resistant, integrated solenoid which continues to operate even at extreme temperatures.
Mean Green High Output Alternator $355 SHIPPED NO CORE !!
The Mean Green High Output Alternator is the answer to all of your charging problems. The Mean Green Alternator provides up to 300% more power than stock. The Mean Green Alternator can charge any engine no matter what its' power requirements.
Superior Design
Easy 5 Minute Installation
Up to 300% More Charging Power
No More Charging Problems
1 Year Unconditional Guarantee
Precision Balanced for Smooth Operation
220 AMP Output
No Core Required
The Mean Green Alternator's tool steel rotorshaft is supported at both ends by heavy duty double sealed bearings. Even the heavy duty solid copper starter windings are sealed with high temperature insulation. That's one reason we include a 1 year Warranty at no charge on every alternator. Another is the heat resistant, multi-function integrated regulator which continues to operate even at extreme temperatures.
Special new castings permit use of stock bracketry and bolt hole locations. Even the stock wiring harness can be used for easy plug in. Designed to out last and out perform any other unit. Great for use in ambulances, tow trucks, motorhomes or vehicles with off road lights, winches, stereo systems or other power accessories.
For more info and to see if there is one for your truck check out the link .. almost every dodge is available
http://www.mean-green.com/ALTERNATORS.html
PM me to order .
Thanks
ramhunter9
ramhunter9
I know someone that NEEDS one ... Guess who ?
ramhunter9
ramhunter9
LOL ... you got it
reddot
Wolf Point, MT
5.9 cummins
GET OUT OF MY HEAD!!!!
ugh your killing me Dave. I might cry.
USMC1188
SW Ohio
None
Truckless...
These things are awesome! When my starter goes out... again... I will be gettin one from ya
ramhunter9
ramhunter9
With all the **** Reece is pushing ... this product will save him in the long run .
I ordered one for my truck today also .. I am running 2 kicker amps that push power .. my OEM alt cant take it to long . Now it will !
reddot
Wolf Point, MT
5.9 cummins
but for real I was just thinking about both of these on my way home from work today. But for real, I have not even gotten the last TWO things I got. lol(not due to any issues just normal shipment). Any chance of a combo deal. Please PM me when you have a chance. Also info on the amsoil stuff. I kept looking and could not nail down what I needed for the install I want to do. But I need an oil change pretty bad. Thanks Dave.
ramhunter9
ramhunter9
LOL .. pm heading your way again .. And check your PM box .. I gave you tracking on the other 15 items you bought the other day .. LOL
reddot
Wolf Point, MT
5.9 cummins
yep got them. pm back to you. picking up the air system from ups tomorrow. And I cant believe how fast the winch shipping is. WOW.
ramhunter9
ramhunter9
Mr Reece now has a bad ass ALT and Starter heading his way ..... this truck is going to be a unstoppable beast
reddot
Wolf Point, MT
5.9 cummins
its true. but this time im REALLY going to start saving for that trans work...... Im going to go make my tinfoil hat now to keep you out.
ramhunter9
ramhunter9
LOL .. I know when its trans time you know where to find me and save lots of money .
