Hellwig Rear Sway Question
RobHinton
2013 EXPRESS
HEMI 5.7
I had a shop put in my belltech drop and hellwig sway. I peeked under and noticed the ends of the sway has two bolt holes? Can someone tell me the difference? Mine is bolted on the inside and not the last one.
Also, anyone have problems with shock mount bolt on back shocks? Ive had to go back twice now bc they are coming a loose and theyre saying they are having problems getting to them.
WhiteExpress
Midland, TX
The Hellwig bar should have 3 holes.
This allows you to adjust the effectiveness of the bar.
With a drop kit, you will see benefit from having proper length end links so the bar sits parallel to the ground. This is the 'most effective' position for the sway bar.
R
RobHinton
2013 EXPRESS
HEMI 5.7
Thanks. Im guessing they used the middle hole for the middle setting. Is there a lot of difference in the three selections?
Etroze86
Grand Forks ND
Crows foot and they won't have troubles getting to that top bolt.
Sent from my XT1080 using Tapatalk
R
RobHinton
2013 EXPRESS
HEMI 5.7
Etroze ... they didnt have one initially. Told me it was good and I left to find out both worked themselves very loose. Now I have been back twice since theyve used the crowsfoot and the back passenger side keeps coming loose. I dont understand it
DavidRam
SoCal - Redondo Beach
2012 RCSB
Not a huge difference, but noticeable. It's a matter of choosing a setting and seeing how it handles, and then adjusting if need be. Maybe hit some turns really fast and see how it feels.
R
RobHinton
2013 EXPRESS
HEMI 5.7
Thanks. Since i had the lowering done and the sway bar added at the same time I wasnt sure how much just the sway bar may have impacted the ride. It handles a lot better, but rides a lot rougher of course. I was just curious if/how much of my ride comfort I would get back if i have them switch it to the moderate selection.
DavidRam
2012 RCSB
If you are in the middle you are at moderate or medium setting. If you move it out it will loosen it.
Etroze86
Grand Forks ND
You may need new bolts but I know there is pretty high torque for the top mounts so maybe they aren't torqued enough.
R
RobHinton
2013 EXPRESS
HEMI 5.7
Thanks for all the help guys. I plan on having this thing for a while and not knowing a lot of the mechanical stuff leaves me nervous.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Doing my BT 2/4 and front and rear Hellwigs when I get back from out of state, easiest way on rear is to pull inner wheel well liner to get to shock bolts.
R
RobHinton
2013 EXPRESS
HEMI 5.7
Thanks for that tip. If they come loose again I will def try it.
MR.REMBERT
Santa Barbara County, CA
All good info here. I went all the way stiff with my rear sway and love if. Upgrading the front sway bar was night and day. And like previously mentioned, although it was a pain the the ass, remove the well lining. MUCH easier. Hope you get it figured out.
R
RobHinton
2013 EXPRESS
HEMI 5.7
Been away a while and just getting back to getting the adjustments done. When you all say move to the outer hole I am guessing that this means the hole furthest to the rear bumper. correct?
DavidRam
2012 RCSB
The hole closest to the rear axle is the most aggressive (allows the least movement), the hole furthest from the axle is the least aggressive (allows the most movement).
R
RobHinton
2013 EXPRESS
HEMI 5.7
ten4. Thanks for the clarification. Appreciate it.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Rob, I have my rear swaybar set on the softest setting which is the hole closest to the rear bumper. The ride quality is not bad at all with the 4" rear drop, so I would start there.
