help 4low stuck and had to tow it home
treearborist13
5.9 magnum
I need help I had to tow my truck in 4low for 5 miles and the transmission got hot and fluid started to come out of the dip stick for the transmission. Will my transmission be ok? Could it have done damage? It didn't lock up and no grinding I let it cool Down . Will it be ok ?
RamV10
Western Central NV
V10
What does the fluid look like? Is it black or burnt. Why didn't you remove the driveshafts?
You'll only know when you start your truck & drive it to know if you did any damage. Getting them hot is never good.
T
treearborist13
5.9 magnum
I couldn't remove drive shaft I was in the middle of no were with limited tools. And the fluid is still reddish color. It only got hot very briefly and I pulled over and stopped right when it got hot let it cool down had a buddy bring some tools and manually took it out of 4low into neutral and finished towing it home do you think it will be ok? Thanks
Csanders1992
Was your truck running?
Merc225hp
NA
truck
gas
We can't answer that Q for you, you will have to drive it and see how the tranny works/shifts.
FlyinHaYn
Midwest
Depending on how fast you were being towed, it could be promising.
ChloeBrooks
