Help deciding on tire/rim size
heater
I can't make my mind up on what tire/rim combo to go with, hoping some different opinions might help me decide. I just bought a 2014 bighorn CC 4x4 6.4 box and I will be installing bilstein 5100's front and back, as well as a 3/4 spacer in the rear and Boss air bags. I drive on rough city roads, lots of back roads and a good amount on highways. I'm stuck between 285 70 17, 285 75 17 (fewer options) and 275 65 20. What's your preferred size and why? Thanks in advance for the opinions.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
If you're bringing the front up to 2.8" then I'd be going with a larger tire than what you have listed. Personally I'd recommend a 20x10 -12 offset and either a 295/60/20 or 35x12.5 tire depending on how much you want to fill up the wheel well.
The best thing for you is going to be looking through pictures of different setups to determine exactly what you like the best. I'd recommend taking a look at Custom Offsets.
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
275/65r20, cause it's what I have.
Toyo A/T 2's, cause it's what I have.
Rims gotta be black, cause it's what everyone else has.
Octanes!, cause it's what AB suggested.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
I agree with Brandonon this... If you're going to get Bil's all the way around as well as spacers, I'd consider a bigger tire. But it really all depends on the look you're going for.
Adam
gofishn
Iowa
hemi 5.7L, 345 cu in
I don't get it.
Bit of an ********, raise your hand.
SO mostly an ******** would be raise both hands and being the very definition of an ********, only thing left is to actually fly.
Wife's been calling me an ********, for over 32 years, reckon she should know.
H
heater
Thanks for the ideas guys. I'll keep looking a pics and figure something out.
Arturo Rojas
