Help! Dreaded lightning bolt warning light is flashing!
KEN COBLE
Fort Worth, TX
2007 Ram Big Horn w/5.7L Hemi. Help! Dreaded lightning bolt warning light is flashing. Got up to go to work Wednesday morning, and truck had a hard time starting. Once it started, it ran extremely rough, and I had no throttle response. The lightning bolt was flashing and check engine light is on. Was told it was a bad throttle body. Replaced it, and zero change. Pulled codes
P0113/P0522/P0335/P0112. My next step is to replace the IAT sensor, although I don't believe that will fix it. IMO. Is there a relearn procedure for the new throttle body. Any help or advice would be much appreciated.
MADDOG
Living in a Firepit
P0113 indicates that your Intake Air Temperature (IAT) sensor is reading at too high of a voltage. The PCM sends the IAT a continuous current of five volts, and monitors how much voltage it gets back. The fault could be caused by a bad sensor, a bad connector or a short in the wiring harness to the sensor. Check the connections first to make sure they aren't corroded or dirty.
P0522 indicates the oil pressure sensor is sending a low voltage message to the PCM. A vehicle will store P0522 when that message tells the PCM that the sensor is indicating too low of an oil pressure value. This can be caused by a faulty sensor, a short in the wiring harness or bad connectors. Check your harness connections. Note: This is the second code that could be caused by a wiring harness fault.
P0335 indicates the PCM is not receiving the correct reading from the crankshaft position sensor. This can be caused by a faulty sensor, a short in the wiring harness or bad connectors. Check your harness connections. Note: This is the third code that could be caused by a wiring harness fault.
P0112 indicates that the IAT sensor reading is too low of a voltage. The PCM sends the IAT a continuous current of five volts, and monitors how much voltage it gets back. The fault could be caused by a bad sensor, a bad connector or a short in the wiring harness to the sensor. Check the connections first to make sure they aren't corroded or dirty. Note: This is the fourth code that could be caused by a wiring harness fault.
Given that all four codes you read could be caused by a wiring harness fault I would suggest you start by inspecting the harness leads to the PCM, check the harness for areas of abrasion or other damage and also check the main harness connector to the PCM (harness end and PCM end) for any dirt, corrosion or other damage at that connection.
vdemarco
San Jose
I agree with MADDOG, i would start by checking the 5v reference circult, make sure that there is 5v there.
Tons of videos on that, this video isn't about your specific truck, but it all applies anyhow.
chri5k
USA
Diesel
Perhaps Squirrels or other rodents messed with the wiring harness. Those buggers can do some damage.
