Help get Silver running again!!
S
Silverbullet08
Persona Non Grata
something was leaking oil... turned out it was the gasket on the valve cover that got messed up when i put it back on last
cruising around 65-70 they were around the -10 around that area. is that normal?
Yes, that is right around where mine are when cruising. When you are feeling it stumble at idle or when you stop it is probably pulling a little too much fuel and leaning it out. At least that is what would happen with me when I first reload the tune.
ok that is good. how long did it take for yours to learn it fully
Well, I would say about three days worth of key cycles. You know, drive it to work, drive it home, a couple trips after work. Do that for a few days and the stumble should be gone.
sawcut64
Arlington/DFW Texas
Another thing to remember Nick is even pinhole leaks in exhausts can cause issue's with some trucks and depending on where they are located. Try to get that one O2 **** plugged, small leaks can cause a vacuum affect with the exhaust flow because the exhaust flow kind of pulsates. A hole will blow exhaust gas out and suck in outside air effecting O2 readings.
S
Silverbullet08
Persona Non Grata
im stopping by the shop to see if they have one before i go.
holy crap! this thing pulls now!!
S
Silverbullet08
Persona Non Grata
yea i just tried on the highway lastnight. punching it at 60. got it to 80 in no time. love it!! this was all worth it!!
glass3222
Central PA
Glad it is running well...... now where is the 0-60 time and video?
Ram Man
FL
2013 Sport
Now I think we can officially say, well done and good job af and bullet!
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Glad to here it's runnin good Silver!
truckin151
2013 sport
Glad its working.......now where are those numbers? Lol
noraa73
