Help!! Need help with new wheels
Niteboss
I have a 2014 express ccsb 4x4. I have the adjustable Bilsteins set at max height and 1.5” spacers in the rear with bilsteins.
I currently running 295/55/20 KO2’s On the stock 20” wheels with 1.5” wheel spacers.
The wheels Im looking at are 20x9 with a -10 offset. I cant find info on backspacin, but assume they are 4.5in.
I’d like to know is,with the -10 offset, will my wheels stick out further?? I am going to assume just 10mm.
Thank you in advance
N
Niteboss
Heres how she looks now
Cableman
Longisland
4.5" back space, 1.25" more out wheel well over a stock 20x9.
N
Niteboss
Thank you
that’s quite a bit too much..Maybe I’ll go with +10 that should only be about 3/4” instead
Cableman
Longisland
I have 20x9.5 -6 offset which is also 1.25 more out then stock and its great, but i do have factory flares.
The wheels you are looking at will stick out ¼" less then your stocks with spacers
N
Niteboss
Im just so confused. I really dont want the tire being an inch more out of fender, than it is now.
Heres what I found for the wheels.
Backspacing: 5.39
Offset: +10
Wheel Diameter: 20
Wheel Width: 9
Hub Bore: 110.20
Load Rating:
Wheel Exposed Lugs: No
Wheel Material: Alloy
Wheel Weight:
N
Niteboss
Thank you. I also have stock flares, but I am going to switch to the rivet style. Which are 1” wider.. I want to have the tires close to flush with the wider flares.
Cableman
Longisland
You may wanna look into a 20x10 wheel then, anything from -12 to -25 would do
N
Niteboss
The 1/4” less would be for the -10 offset or the +10 offset.
Cableman
Longisland
-10. A stock 20x9 has 5.75 bs, so just look at how much less bs a wheel has and if its wider add it to outside
N
Niteboss
The wheel Im looking at has 5.39”bs with a +10 offest. If I get the wheel with -10 that should be a bs of 5.8”
The stocks have 5.75 bs. So if I went with the -10, it will only move the tire out a little bit with the 1.5“ spacers
N
Niteboss
Just want my tires out 1” more than now
So i will need 20x10 wheel with -18 to -25 offset??
Cableman
Longisland
Maybe this helps a little
Cableman
Longisland
A 20x10 with -18 offset has 4.75 bs so that is 1" less then stock and the wheel is 1" wider, so that gives you 2" further out from stock and ½" more then your current setup.
So for what your looking to do i would say 20x10 -25.
Check out customoffsets and plug those wheel #s in and there is many pics
N
Niteboss
My math went bad on me here. If the aftermarket 9” wheel with +10 offset has 5.39 bs. Then with the -10 offset the bs should be close to 5”.
And the stock wheel has 5.75” then the new should stick out roughly 3/4” more than they are now.
